Author Topic: Understanding N76E003 startup file by Keil  (Read 1330 times)
Offline Vindhyachal.taknikiTopic starter
« on: July 21, 2018, 10:44:41 am »
I am working on Nuvoton N76E003 MCU & using Keil C51 for this. Keil added a startup file. I have below problem in understanding it:
1. Attached find the keil startup file.
2. The datasheet of N76 says it has 256 bytes of Idata RAM. & 756 bytes of Xdata.
But startup files on line 25 says:
IDATALEN EQU 80H ; the length of IDATA memory in bytes.
Is it an error?
3. But line 45 says
IBPSTACKTOP EQU 0FFH+1 ; set top of stack to highest location+1.
where stack is defined at top of RAM i.e 256 bytes.
Or this startup uses 128 bytes as RAM & fix rest of remaining top 128 bytes as stack space?
« Last Edit: July 21, 2018, 10:47:04 am by Vindhyachal.takniki »
