Author Topic: help id part - maybe thyristor  (Read 1440 times)
Offline fxkl47BFTopic starter
« on: March 26, 2023, 11:19:29 pm »
a friend found a couple of these
he wanted me to id them but i can't find a datasheet
my cheap little component tester calls it a thyristor
Online janoc
Re: help id part - maybe thyristor
« Reply #1 on: March 26, 2023, 11:30:47 pm »
Assuming that 7807 is not a date code, that looks very much like an old 7 volt fixed voltage 78xx voltage regulator. Those did come in TO-3 package.
The little tester would be pretty confused by that for sure.
« Reply #2 on: March 27, 2023, 01:36:27 am »
i looked up the numbers across the top, 108 046, and found a lot of foreign chips but no datasheet
a lot of folks selling them but no description of what they're selling :)
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #3 on: March 27, 2023, 04:36:57 am »
I very much doubt that it is a 7V regulator. I don't think any of the standard 3-terminal regulators came in a 7V version.
THe 7807 is most likely a date code.
Online janoc
« Reply #4 on: March 27, 2023, 09:36:33 am »
No idea why would you think so:
https://www.digchip.com/datasheets/download_datasheet.php?id=6878552&part-number=LM7807-TA3-T
ST also used to have L7807 but it is not made anymore.
LM78xx came in fixed voltages from 4.7 to 24V, in one volt steps between 5 and 12V.
Granted, 7V is not very commonly used but that doesn't mean it didn't/doesn't exist.
« Last Edit: March 27, 2023, 09:53:34 am by janoc »
Offline shapirus
  • Country: ua
« Reply #5 on: March 27, 2023, 09:40:20 am »
What a nice piece of history.
Offline Gyro
« Reply #6 on: March 27, 2023, 09:46:04 am »
From the general look of the package and markings, I would say that it is a 1970s vintage part, with relevant date code. The part number has the look of an in-house part code (HP or Tek for example).
Best Regards, Chris
Online janoc
« Reply #7 on: March 27, 2023, 09:54:53 am »
That's possible too. I would also check whether there isn't any marking on the side of the can, instead of the top. Some manufacturers did put their markings there as well ...
Offline srb1954
« Reply #8 on: March 27, 2023, 09:55:41 am »
Back in 1978 the 7807 didn't exist. Neither did Unisonic Technologies.
Please produce produce a datasheet dated 1978 or earlier showing a 7807 in a TO-3 package to support your claim.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #10 on: March 27, 2023, 11:32:52 am »
All I can find is that all Chinese sellers claim this is a high power transistor for ultrasonic welding equipment, and one of them mentions Branson 8700.
« Reply #11 on: March 27, 2023, 03:27:34 pm »
that's all i could find
no mention of specs
Online janoc
« Reply #12 on: March 27, 2023, 10:15:01 pm »
Sorry but I am really not going to spend hours now to dig through old catalogs for you. These things aren't all available online and pretty much everyone and their grandma made copies of 78xx regulators in TO-3 cans. Even in the Eastern bloc - I still have some MA7805s made by Czechoslovak Tesla around.
If it is actually a 7807 regulator it obviously wasn't made in 1978 because then that would be the part number and not date code.
I also never claimed it was an Unisonic part, only that 7V versions of the 78xx regulators do exist. The can has an obvious RCA logo, as far as I can see.
 If it was a transistor then I would assume the cheap tester would identify it as one and not claim it is a thyristor (SCR).
« Last Edit: March 27, 2023, 10:28:08 pm by janoc »
Offline srb1954
« Reply #13 on: March 28, 2023, 07:22:56 am »
Yes, practically everyone except RCA. Looking back through their old catalogs you find they had very little to offer in the linear power IC range and as far as I am aware they never did jelly bean chips like three terminal regulators.
I checked a variety of RCA metal can devices and, in all examples, the part number was arranged circularly above the RCA logo in the 10AM to 2PM position. In the 3 to 5 position was the 4 digit date code and in the 7 to 9 position was an alpha-numeric code, which could be a mask number or manufacturing plant code. So, on an RCA marked part, there is simply no way that the 7807 code could be interpreted as a part code.
It could easily be an SCR. RCA used to make a wide range of SCRs and TRIACS, many of them in TO-3 packages.
Offline Haenk
« Reply #14 on: March 28, 2023, 12:58:40 pm »
Looking at google pictures, the 7807 is without doubt a datecode. Case closed - it's not a voltage regulator.
So essentially, you could look up a 1977/78 databook and see what has been on offer - however it even might be a customer-specific production.
Online wraper
  • Country: lv
« Reply #15 on: March 28, 2023, 03:43:54 pm »
IT's easy to figure out what it actually is by doing some measurements with multimeter. Of course it will not provide you specs but you'll figure out what type of part it is. Most likely it's off the shelf part but with customer specific part number, so you won't find it in databooks unless  you figure out which usual part number hides under this customer specific code. As it's supposedly ultrasonics related, I expect it to be some sort of high voltage NPN transistor.
Offline amyk
« Reply #16 on: March 29, 2023, 12:29:09 am »
I found some sketchy references to it being equivalent to NTE327 180V 25A NPN.
« Reply #17 on: March 29, 2023, 06:17:43 am »
thanks, i'll pass along this info
Offline Zero999
  • 0999
« Reply #18 on: March 29, 2023, 01:02:46 pm »
Those circuit testors are generally fairly good. It's probably a thyristor, if it says so.
Have you bench tested it to ensure it is a thyristor?
« Reply #19 on: March 29, 2023, 01:30:50 pm »
i haven't
Online wraper
  • Country: lv
« Reply #20 on: March 29, 2023, 02:12:33 pm »
IMHO instead of stupidly relying on these cheap testers everyone who deals with electronics should know how to do component measurements with multimeter. Diode mode is vary handy for testing different semiconductors. I learned how to do it when I was around 10 years old and it was one of the first things I learned.
