A lot of standardized Engineering, at least from 1940's on, would frequently use the phrase:
'Derate Specification maximums 10 %, for safety margin'...I mean, I guess you obtain some measure of efficiency, running a subsystem on 4 ICs, biased up at 98% of power supply, 95% of rated max current, rather than 'buying' 6 ICs for your planned subsystem, and, God forbid, run them at conservative design points,
and then get on with the whole rest of the design overview.
Folks designing ships, high-rise buildings, hospital procedures, etc. ; They don't start out, at the furthest, ragged edge (of safety), as possible. So...uh...are you, checking the absolute maximums, carefully, so that then, knowing those, you can, also, derate the design, carefully, (how about by 15 %?).
Or, is the one margin enough ?
The (limited) skills I learned, always appeared as Engineering as a profession, isn't just numbers; it's an approach, reliability, safety, testing, all come together, if that's what you seek. ?
