Hello together,
I have a SMD component which I try to identify. I checked several websites with smd lookup tables but nothing seems to fit.
On the SMD component is written "CVV". The component is a SOT-363 (or SOT-23-6) component. Pin 2 and 5 are shorted together, Pin 3 is +5V and Pin 6 is -5V.
Pin 2 and 5 are connected via voltage divider to an opamp output.
My guess is that the component is used for output saturation protection or impedance control (maybe both). Application of the whole circuit is audio amplifier.
Maybe the wanted component is another opamp or transistor array. Maybe from Fairchild/On Semiconductor.
Maybe someone has an idea.
Thank you very much!
