Author Topic: Understanding series wound DC motor waveform ?  (Read 2235 times)
Offline nurbsterTopic starter
« on: September 30, 2018, 03:20:29 pm »
Hi Forum.  Can somebody explain what is wrong with this motor based on voltage and current waveforms ?  This 12V motor should draw somewhere around 10A, don't have specs, but I do know that 24A+ is definitely not right.
Thanks, nurber
« Last Edit: October 02, 2018, 02:25:30 pm by nurbster »
Re: Understanding series wound DC motor waveform ?
« Reply #1 on: September 30, 2018, 03:21:39 pm »
I don't have a reference of what a good series wound DC motor should look like so would appreciate anybody that can provide a link.
Offline Benta
« Reply #2 on: September 30, 2018, 03:23:17 pm »
The waveforms look fine for a series wound motor. The big question is: what's your mechanical load?
« Reply #3 on: October 01, 2018, 12:38:20 pm »
Thanks for replying. This is without a load and motor seems to spin easily enough so I don't think it's an issue with bushing, bearings, etc.
Offline Benta
« Reply #4 on: October 01, 2018, 01:07:23 pm »
NEVER run a series motor without load. It will accelerate towards infinity, worst case the anchor will disintegrate.
As it is now, it's running at far too high rpm, which explains your excessive current draw.
Another point: series DC motors are very often timed for a certain rotation direction and will not perform well if reversed.
« Last Edit: October 01, 2018, 02:48:44 pm by Benta »
Offline jmelson
« Reply #5 on: October 01, 2018, 07:55:30 pm »
While, in THEORY, the above is true, it neglects windage and armature iron losses, which both increase with speed.
So, unloaded series motors will generally not explode or be damaged without load, but they will run at the highest speed where those losses reach equilibrium with the energy coming into the armature.
Series motors will ALWAYS run in the same direction, regardless of power supply polarity!
Unless you have switching to reverse the respective polarity between the field and armature, they will always run in the direction designed by the manufacturer.
Jon
Offline jmelson
« Reply #6 on: October 01, 2018, 07:58:38 pm »
You don't give the time scale for your scope trace, so we can't figure out how fast it is spinning.  But, there is a roughly 2:1 fluctuation in current, which sounds VERY strange.  I'm guessing there may be a shorted turn in the armature.  Since the motor is drawing about 200 W by averaging the current and voltage, it does sound like something is wrong.
Jon
Offline Benta
« Reply #7 on: October 01, 2018, 08:06:49 pm »
Jon
To the first point: I said "worst case". As neither of us has the slightest idea of which motor this is, let's leave it at that.
To the second point: My bad! You're absolutely right, my apologies.
Offline xavier60
« Reply #8 on: October 01, 2018, 09:55:06 pm »
An unloaded Series DC motor speeds up because of the reduced current draw which weakens the field. The armature needs to spin faster for its generated EMF to almost match the supply voltage.
« Last Edit: October 02, 2018, 02:57:28 am by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
« Reply #9 on: October 02, 2018, 02:26:34 pm »
thanks for informative replies.  I uploaded an uncropped version of original image in first post that shows the timescale.
« Reply #10 on: October 06, 2018, 01:46:02 am »
I used an insulation tester on this motor measuring approximately 50 megaohms @ 250V  between leads and shaft as well as between leads and enclosure.  I'm not experienced enough with such a tester, but I believe this is indicative of a fault ?  I then opened up motor to reveal windings that looked darker than normal ( perhaps heat damaged ) and continued with insulation testing showing the same 50 megaohms readings between leads and lamination stack.  Resistance measurements between commutator bars ( 180 degrees and adjacent ) seemed normal.  Can anybody comment on insulation testing measurements ?  What is the methodology experienced people would use to troubleshoot this motor in the field ?  The insulation tester can reveal interesting things because you don't even have to open up the motor to get to individual commutator bars and so it seems valuable to try when first diagnosing, but I would appreciate knowing how others would approach this situation.
Offline amyk
« Reply #11 on: October 06, 2018, 04:14:26 am »
50MR seems OK for a 12V motor.
If that timescale is in seconds, that is really slow for this type of motor... I count ~55 commutations in 1.2 seconds, which even if assuming you have a tiny 6-bar commutator is only around 500 RPM.
We need more information about the motor, but based on what you've given so far it doesn't sound right for a series DC motor to be turning at that speed with no load. I'd expect well over 1000 RPM.
