I have a trailers with 1kW load that is moved around and often runs for 2-3 days from mains extension lead.
I want to put up some solar on the trailers so that the load is offset by the solar generated. I don't want to have battery, and don't want any infeed, and it all needs to be self-contained in the trailer.
So basically, I need an inverter that preferences DC but uses mains as required so that it always can output 1kW.
The problem I am having is: I don't understand what solar inverter to buy. What kind of inverter is this called, is this something that even exists?
Or I am simply overthinking this? If I just put a grid tie inverter and load in parallel on the extension lead, then put the Solars CT up stream of both (on the incoming live) and set it to never export, it should work fine?
