I need some help to understand a circuit.
SRCLR and RCLR are always at 5V so always HIGH.
If IC 2162 pin 6 is LOW then the voltage after R2168 is grounded as it flows through D2165 towards ground by three state pin 6 of IC 2162.
This is what brings IC's 2165 pin 12 to LOW.
Both D2165 and D2166 stop current from flowing from processor and IC2162 into RCK so they can IC2162 and PROCESSOR do not send each other current.
Is the assessment correct?
