The collector load in the textbook diagram is an incandescent lamp (resistor), not an LED. Although the lamp resistance is not constant (positive temperature co-efficient), it will limit the current into an almost short-circuit (saturated C-E of the transistor).
Thanks. I just assumed it was an LED. Reading the text, I guess I made an assumption of what operating region the transistor was in. That's something I always had trouble with. I just assumed the forward active region rather than saturation. When the transistor is on, because there's no current limiting resistor at the collector or the emitter, the transistor will want to pull as much current as possible. The only way it can do that is by having the collector voltage be as close to the emitter (ground) as much as possible. Ideally, the collector would reach ground (assuming a very ideal switch behavior), but it doesn't; we don't know the voltage of the collector, but we can assume that based on its assumed behavior, the collector voltage is low enough to make the BJT go into saturation. Is this correct?
This sort of behavior looks like it would blow up the lamp, though 100 mA doesn't seem like much.
Very probably the base current is high enough to drive the transistor into saturation. You can get the V
ceSat value from the datasheet but it usually on the order of 0.2V. The same as V
be will be about 0.7V. If you don't get a low V
ceSat, you might not have enough base current. For most switches, I assume an H
FE of 10 so if I need 1A in the collector, I design to 0.1A of base current. I certainly don't assume an H
FE of 100 or 200.
This is what experiments are made for. Come up with a reasonable load for an appropriate transistor and measure I
b when you get V
ce into saturation. Measure the collector current at the same time. This is one of those cases where 3 meters come in handy. I
b, V
ce and I
c. V
be might be interesting as well. Need another meter... You don't seriously need 4 meters but it sure does help to match up all the numbers at the same time.
Look at page 2 of the 2N2222A datasheet and reflect on what is happening to V
ceSat when the collector current changes from 150 mA to 500 mA. Note also that both values have the base current as 1/10th of the collector current.
Look at the base-emitter voltage (nominally 0.7V as I said above) is actually 0.2V to 0.6V at 150 mA collector current but as high as 2.0V at 500 mA.
There's a reason that all those numbers are given. They define specifically where the 'corners' are when designing the device into a circuit.
https://www.onsemi.com/pdf/datasheet/p2n2222a-d.pdf
