Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
.EPS pcb layout from Eagle files?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: .EPS pcb layout from Eagle files? (Read 3015 times)
Chris Wilson
Super Contributor
Country:
Race car engineer, dog lover, hoarder.
on:
January 02, 2014, 11:46:22 am »
I have two Eagle files and need an .EMS file from them. I do not have Eagle. I just want the file to print the transparency to etch a couple of boards. Can someone tell me if the files attached will convert to produce an .EMS file and what i need to do this please? Or if it's dead straightforward for an Eagle user, maybe they could convert to.EMS and post it up or mail it me....
Thanks!
Logged
Best regards,
Chris Wilson.
kc9qvl
Regular Contributor
Country:
Re: .EPS pcb layout from Eagle files?
Reply #1 on:
January 02, 2014, 01:51:03 pm »
If you are going to etch yourself. Just print the brd file as a mirrored black pdf.
Last Edit: January 02, 2014, 02:02:35 pm by kc9qvl
Logged
Chris Wilson
Super Contributor
Country:
Reply #2 on:
January 02, 2014, 01:56:28 pm »
Thanks, I'll download it again, but if it had errors would the zip have even opened?
Logged
Best regards,
Chris Wilson.
kc9qvl
Regular Contributor
Country:
Reply #3 on:
January 02, 2014, 02:05:49 pm »
Eagle is complaining about erc errors. not set junctions. Is this supposed to be a 2 sided board? ground plane on top?
Logged
Chris Wilson
Super Contributor
Country:
Reply #4 on:
January 02, 2014, 02:23:05 pm »
I thought it was a single sided board. Let me find the link....
This was it:
http://www.feedpopular.com/read/aHR0cDovL2NpcmN1aXRzZGl5LmNvbS9sbTMxNy1yZWd1bGF0b3ItYm9hcmQtcGNiLW1ha2luZy8=/TE0zMTcgcmVndWxhdG9yIGJvYXJkIFBDQiBtYWtpbmcgfCBDaWN1aXRzIERJWQ==
Thanks.
Logged
Best regards,
Chris Wilson.
kc9qvl
Regular Contributor
Country:
Reply #5 on:
January 02, 2014, 02:33:51 pm »
Ok for transparency method
Logged
Chris Wilson
Super Contributor
Country:
Reply #6 on:
January 03, 2014, 10:58:10 am »
Quote from: kc9qvl on January 02, 2014, 02:33:51 pm
That was really good of you, many thanks. If I print at 100% size straight from the .pdf file, should the image size be correct? Hole spacing for the header connectors and LM317 seem correct at 100%
Thanks again!
Logged
Best regards,
Chris Wilson.
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
