It seem that you missed the point of this thread.
You are so busy to make others to accept your opinion, that you forget how the discussion was started.
My opinion?? Again, I am running meters to a somewhat standard and presenting the data I collect. My opinion has nothing to do with it.
While I am not an expert I am not ignorant in ESD . My experience prove me that with some precautions measures you can avoid more troubles. But this is not a guarantee, obviously.
I was saying that UNI-T does not lack input protection. It is not on the level you test it . But as I can measure anytime in the range they specified is not a problem for me . ESD events can appear and destroy even a Fluke .
What you did is you made a claim about what I personally could say. You based your claim on your feelings about what you see inside of a meter when you looked at it with your unprofessional eyes and formed your opinion about it. In your ignorance, you failed to understand that the layout is part of that system. While I have demonstrated time and time again how poorly UNI-T products perform in these conditions compared with many others, you only offer your opinion.
Obviously, if you are going to be posting about me and what I can and can't claim, I am going to call you out. It's not my ego, it's yours that can't expect that you don't understand what you are looking at. You can't believe that you have 30 years experience and don't understand the basics. Again, that's not my problem. You could correct this but your ego will not allow it.
As you said you can stressed any meter to failure . So what is you point then ? Some meters are better than others . We all know .
Your sentence following your question IS the point!!! You follow with, we all know. In my case, I will certainly claim my own ignorance on this subject which is why I started running these tests in the first place. I was pretty vocal, stating my opinion about Fluke before I started testing and I was wrong. I have no problems admitting that. It was an opinion, based on a very small data set of one very old meter.
You cannot guarantee that a Fluke, Brymen or any meter that has pass you test will not get blown if an ESD event will happened. So again what is your point ? You can guarantee that my Fluke will not be blown, because on your test it pass ?
Again, this is your ignorance on testing. Of course I can not predict all individual cases. What I can and have done is show how my grill starter and later my gun compare with the IEC standards. I can capture how I perform the tests on video and make it available free to the public. I can record my findings into a spreadsheet that is easily and freely viewed by anyone who cares to learn from them. I can subject many (I think there were over 70) products to the same ever increasing levels of severity to see how they compare. I can see trends in this data and point them out.
The UNI-T can measure mains without any problems unmodified . I don't care if you are not happy with this or not .
I've been upfront that my testing has NEVER been about safety. If you need a product to work on mains in CAT III and up, I expect you are well educated. Personally, I am not an electrician. I seldom have a need to poke around the AC lines. When I do, I have the proper equipment for it. I am fine with other people doing what ever they please as long as it doesn't effect me. I tell people all the time, I am not selling meters and could care less what people buy or how they use their products.
My truth?? I just collect and present data. ...
Your ignorance is obvious .
You defend your findings . You are so identified with this so you begin a crusade against every man that even just touch your work .
Forgive me for disturbing your ego .
Forgive me that I am not granting you the importance that you deserve .
I am so sorry that I've been upsetting you Master, the keeper of all ESD knowledge in the world
I expected no less from you.
As for evava's original post on BW, I normally measure the 3dB point as part of my reviews now. UNI-T and some of the other lower end meters are typically faster in this area. The same with the frequency counter. Having this higher BW appears to come at a price (or lack of it). I made a series of videos about a UT61E because it is such a popular meter. I had damaged them with the grill starter (no surprise) and decided to show the reason why this particular meter is so easily damaged. As part of this, I changed a few circuits. One of the things I showed was how it effected the BW. It was certainly not what I consider optimum, but was more just to try and educate people that may want to understand a basic problem like this and how to solve it. Personally, I don't consider a handheld meter when looking at >> 100KHz signals. I would rather give up BW to have a electrically robust product.
