yes, edit the eeprom.
it's the same chip as the uni-t ut210e, so look in the thread about it.
here's the memory map btw.
if you set the light delay to 0 it stays on till you turn it off - manual control.
you should also push the auto-power off back from the standard 15min's to maybe an hour.
