So, Serial Communication (RS-232, and RS-422), and not I2C. That's a start. With open-collector bus terminology, it looks like you need 3 terminals (the IC output, the open collector, and IC ground), so that's 3 fibers? If that's the case, taking I2C as an example, 2 fibers can be SCL/SDA, and you can just transmit power/ground through another method. Am I wrong?
