Is it possible?
For example, I have a 56k modem with a reed relay, bridge rectifier, speaker, inductor, electrolytic caps and resistors up for grabs if I could get them off the board. But I can't. They are through hole components but of a very fine pitch it seems.
I have tried a solder pump and solder wick (the flux impregnated stuff that is hopefully half decent) but it seems that whatever I do, surface tension retains just enough solder to keep the parts stuck tight.
I have access to a good quality soldering iron but not a rework station or anything like that. Is there some trick to it, or is it just not possible?
I don't have any intended use for these components but then I don't have any use for a 56k modem either, it would only be going in the bin.
