Electronics => Beginners => Topic started by: xoom on July 28, 2018, 07:59:07 am
Title: Unknown BT Module
Post by: xoom on July 28, 2018, 07:59:07 am
Hi, can some tell me what module it is where i can check pinout and try configure it how i need :)
It have CHIPSET: BEKEN BK3231Q
its from ELM327 diagnostic scanner i want to try use for DPS5015 power supply :)
Some pins i figured out from ELM327 scanner but to reprogram i think need more pins :)
Thank you.
Title: Re: Unknown BT Module
Post by: bloodhunter007 on July 30, 2019, 06:21:07 am
Thank you.
dps5015 communication version have own BT board, you should not use other BT
and for your DPS5015 have commnunication function or not ?
Post by: brainstorm on July 18, 2020, 02:18:41 am
Here you have some info and poking around about the Beken, follow the sub-threads for more information:
https://mitxela.com/forum/topic/beken-bk3231
