You can do some measurements yourself.
It you've got an adjustable high voltage source, you can use a series resistor to find it's breakdown voltage (It will start acting as a zener about 20% or 30% over it's rated voltage.)
If you puch too much current through it then Hfe will start decreasing.
Dong a few of such measurements can be educational, but for other purposes, why bother? You can get assortments of some 600 transistors for EUR10 or less.
