The capacitors on one of the differential lines match typical USB3 design. The pinout should be easy to figure out. From top to bottom: ground, diff pair, ground, diff pair, VBUS, one more pair (unused USB2?). The exact pinout could be traced from the differential pairs either visually or using a multimeter.
The connector is clearly not standard, so who knows the exact type. Might be proprietary too.
