I try to simulate charge amplifier, it will be used as a first stage for photomultiplier tube. It doesn't have resistor in parallel to feedback capacitor (C1), instead, when output voltage is close to supply voltage, feedback capacitor is discharged by a transistor (J4).
I found this idea somewhere on the internet, but it was just briefly described, the idea was to avoid noise created by (high value) resistor in feedback loop.
I came with circuit presented below, it kind of works, but when the capacitor is discharged, a rellativelly huge voltage spike is visible on the output.
How can I improve my design to remove this spike?
Does below circuit contains other errors?
Here is link to the LTSpice simulation file:
https://github.com/RobertGawron/PhotomultiplierRadioactivityDetector/tree/master/Simulation/ChargeAmplifierWithAutomaticalReset
