I love this scanner because its the only way to pick up the police radio in my state, sadly SDR's can support the two channels at once that are required, they should invent one that does. Anyways, it has the 4 AA (2X2) square battery pack in the back with the option to charge nicd or nimh (There is a setting in the scanner to do this, but don't see why that would matter).
So how hard would it be to:
A:convert to lion that I would need to recharge the battery separately through a hobby charger (supports all types of RC plane/drone/car batteries) or
B: some how use the charging feature built into the scanner. As far as size goes to get the same mAh how big would the lion be ? And how big to cram in the circuitry?
Since its six volts I would need two cells at ~4volts and then reduce the voltage? I think I used to run it off a 9volt AC adapter, but I don't want to try that again incase I'm mistaken and it gets damaged. Do they make an off the shelf substitute? I know you don't see AA lion sizes because some idiot like me would accidentally stick it in a nicd charger, but you would think that with the small size to mAh ratio of liions they could fit protection and charger chip/buck converter all in one package. Or at least a four AA square sized drop in substitute since many devices use that. I'll probably go with option A at first and if that works i will start trying to make a little PCB with surface mount to make it self contained.
