Author Topic: upping battery voltage on old pentax AF160 flash  (Read 1100 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« on: April 30, 2014, 07:39:13 pm »
I have an old pentax AF160 flash unit. It runs on 2x AA's. I was thinking what is i use a 1.2V NiMH and a 3.6V Li-Ion, that would give me 4.8V instead of 2.4V, the unit will have been designed for up to 3.5V I expect as it would have originally taken alkalines. Is it worth the risk ?
I'm hoping for faster recharge times.
Offline jlmoon
  • If you fail the first time, keep trying!
Re: upping battery voltage on old pentax AF160 flash
« Reply #1 on: April 30, 2014, 08:03:30 pm »
only if you don't mind letting the magic smoke out of that smps power supply.  Think you could have a problem with inrush current along with the sudden much lower internal resistance of those new batteries.  You are doubling the input voltage, not to mention the current  to that device, don't think the engineers had that much tolerance in mind.
Recharged Volt-Nut
Offline Simon
  • Global Moderator
« Reply #2 on: April 30, 2014, 09:27:25 pm »
bearing in mind 2x alkalines are up to 3.3V I'm looking to go to 4.8V
Online SeanB
« Reply #3 on: May 01, 2014, 05:44:23 am »
It will cook. Just use 3 NimH cells and it will charge faster. The limit is the teeny tiny little transformer inside that has resistance you cannot do anything about. Higher voltage and they will melt the windings into a charred mass. If you want faster charging get a new flash unit.
Offline Simon
  • Global Moderator
« Reply #4 on: May 01, 2014, 06:31:58 pm »
I was contemplating as to whether the guts were made to work universally off 3 or 6 volts as many flashes took 4 AA's.
