Done the tin spacer a lot, using whatever can was to hand as the donor. Best was a corned meat can, ready cut strip of tinnes steel from the band sealing it.
When fixing a LED illuminated LCD panel to use as a panel on my workbench I did not buy a mounting kit. I measured the holes and drilled the back panel in 2 places to match, then used 2 long M4 screws that I cut the heads off, and slightly mangled the thread just under the head to lock it in the brass bosses in the panel back. Then I placed it on the panel and used 4 washers and nuts to hold it from the rear flush. Works perfectly, and cheaper than the mount kit, and no added depth as well. Cost was zero as well, the screws, nuts and washers were old ones recovered from dead electronics or were in my oddments bin.
