Author Topic: Trying to find the RGSD8X224K electronic component  (Read 730 times)
Offline maeloterkimTopic starter
« on: January 22, 2022, 03:47:48 pm »
Hi im searching this component but i didnt find anything
i atached an image of the component
1388243-0
I tried googling with some letters combination with no results
if someone can help me to identify it
the component has 9 pins
the text on the component says :  00X22K
the text on the board says : RGSD8X224K
I want to replace with a new one but i dont know what component is and where to find it
Thanks
Offline Neomys Sapiens
Re: Trying to find the RGSD8X224K electronic component
« Reply #1 on: January 22, 2022, 04:47:11 pm »
(Attachment Link)
Thanks
Looks to me like a resistor array. 8x 220k to one common terminal.
« Reply #2 on: January 22, 2022, 04:56:58 pm »
(Attachment Link)
Thanks
Yes i think that this is the answer Thanks
I will try to find someone similar
« Reply #3 on: January 22, 2022, 06:01:33 pm »
if it is useful for someone
i found the 9A103J resistor array datasheet pdf online (easy to find)
and the letters mean :
9 -> number of pins
A -> type of resistors circuit ( A means resistors with a common pin circuit )
103 -> the value of the resistors
J -> the tolerance
I think i will try as a replacement of the RGSD8X224K ( 00X224K) that seems a 8 resistors array with a common pin with a
9
A
224 (220K)
and any letter as a tolerance
easy to find on aliexpress
in aliexpress you must search for 9A103J  or  "Resistor Network Array 9 PIN"  and find a seller that sell different resistor values like 220K
i hope this works :)
Offline drvtech
« Reply #4 on: January 22, 2022, 07:00:40 pm »
A search on eBay for "220k resistor network" gives a few hits. This one for example
 https://www.ebay.co.uk/itm/220K-10-x-8-Commoned-Resistor-Network-9-PIN-SIL-Single-In-Line-150-/361618684935?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
That's a UK seller so might be no use to you depending where you are but you might find something more local.
