Author Topic: USB-C connector  (Read 1146 times)
Offline JaneTopic starter
USB-C connector
« on: March 19, 2019, 12:14:29 pm »
If I plug in USB-C charger into USB-C connector, on which  pins I can   measure  the voltage coming from the charger?
 ( there are so many pins on USB-C connector    )
Offline Deepak
Re: USB-C connector
« Reply #1 on: March 19, 2019, 12:23:59 pm »
USB-C is symmetrical, and you want the GND and VBUS terminals.
Offline timgiles
  • Programmer, DB architect
Re: USB-C connector
« Reply #2 on: March 19, 2019, 12:27:09 pm »
VBUS and ground
Offline Richard Crowley
  • KJ7YLK
Re: USB-C connector
« Reply #3 on: March 19, 2019, 12:39:01 pm »
Remember that USB-C power is NOT static like older, more primitive power schemes.  There are at least three different voltage and current states that are negotiated between the power source and the load. And there is also provision for "proprietary" power modes. So if you simply measure the static voltage, that is only the "default" voltage/current.
Ref: https://en.wikipedia.org/wiki/USB-C#USB_Power_Delivery_Specification
The following users thanked this post: tooki, vignesh_shan
Offline vignesh_shan
  • Country: in
Re: USB-C connector
« Reply #4 on: March 25, 2019, 08:21:47 am »
If i connect the device which requires around 3A current in the USB 3.0 PC. Does all the USB (Type A connector female)3.0 PC provide 3A current?
Also pls let me know the link for device hardware configuration to getting 3.0A current in the Type C connector.
« Last Edit: March 25, 2019, 08:24:02 am by vignesh_shan »
Offline tooki
Re: USB-C connector
« Reply #5 on: March 25, 2019, 01:08:11 pm »
No. The USB 3.0 standard provides for 5V/0.9A, so that's all you can expect to be available.
To go beyond 5V/1.5A, you have no choice but to use USB Power Delivery negotiation. (Not including proprietary charger schemes like Apple's 2.7V sense voltage to get 5V/2.4A.)
The following users thanked this post: vignesh_shan
