Also keep in mind only some of the wires are there.
A standard USB type C socket has two sets of USB 2.0 data pins but only one pair is actually present. You are meant to connect them in parallel to support reversible cables.
The superspeed pairs are optional and any given cable might have 0, 2, or 4 pairs present. You don't connect them in parallel, if you only want to use 2 you need a switch that selects the right pairs based on cable orientation.
CC pins are used for detection and can have an etag chip connected.
