Author Topic: USB cable tester - a thing I wish I had years ago  (Read 319 times)
Offline cfmsoftTopic starter
  • Country: pt
« on: March 01, 2025, 11:12:54 pm »
Hello all.
I recently found on aliexpress a very simple USB tester to test all my camera and iPhone data cables and I really wish I had found this tester years ago. It would have saved me several headaches.
The tester is a very simple board, with on the top side one connector for power, two power side connectors for USB-A and USB-C cables and on the bottom side 3 device side connectors for micro-USB, USB-C and Apple lightning cables.
With it I found immediately which cables are for charging only (do not have data lines) and which cables are broken and ready for the garbage bin.
Example of a good iPhone cable. power and data lines light up, only CC remains dark because only USB-C cables may have that extra connection.
This is an example of a good USB-C cable with all 5 leds on.
Another example of a good USB-C cable that lacks the CC connection, may be good for some devices but not for others.
I found that this cable is for charging only. Has no data lines whatsoever and that's the reason that when I tried to connect my camera to the computer it said there was no device connected...
Last example is a broken cable. Only tho lines are actually connected, the ground and one of the data. Directly to the trash...
« Last Edit: March 01, 2025, 11:21:24 pm by cfmsoft »
Offline Simmed
  • Country: nu
  • im not not not from Niue nor Mongolia
Re: USB cable tester - a thing I wish I had years ago
« Reply #1 on: March 01, 2025, 11:23:53 pm »
not my work, but
The Niue Star is a monthly Niuean newspaper. Its founder, owner, editor, journalist and photographer is and has always been Michael Jackson.
  • Country: pt
« Reply #2 on: March 01, 2025, 11:44:48 pm »
Thank you for your reply.
I Have ordered that one yesterday, but for the last half a year the DT3 has done a very good job for 2.5€ and I think it is easier for other people who do not understand electronics.
