Author Topic: USB High Speed host - IC search help  (Read 5796 times)
Offline desowin
« on: February 22, 2011, 08:25:05 am »
I've spent last few days searching for something that would suit my coursework project.
I think I found a perfect IC for this task - ST ERICSSON ISP1763A, but it's not available anywhere and the minimum order of 1000 (according to the datasheet, for VFQFPN64 package) is definitely no way for me (treat it as hobby project), I would need no more than 10 of them.
So I would like to request some suggestion on choosing another IC for this (or even can be microcontroller with embedded HS host (which can handle two downstream ports)) - I don't need the OTG or Peripheral features (oh, and please no BGA)
« Last Edit: February 22, 2011, 08:26:45 am by desowin »
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: USB High Speed host - IC search help
« Reply #1 on: February 22, 2011, 11:47:50 am »
ISP1760 looks pretty available  - will this do?
Day Job: Mostly LEDs
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #2 on: February 24, 2011, 07:48:00 pm »
Am I missing something here? The popular NXP LPC1768 has Host/Device/OTG and comes in 100-pin LQFP for £7:43. Olimex do a very fancy dev board for €110.
If that is too much, the LPC1754 is £4:53 and 80 pin LQFP.
You can pretty much convert pounds directly to US dollars thanks to the rip-off UK economy.
Offline Jimmy
« Reply #3 on: February 25, 2011, 11:53:14 am »
« Reply #4 on: February 26, 2011, 06:36:33 pm »
You want something like this
http://www.circuitsathome.com/products-page/arduino-shields
That is not high speed. USB 2.0 does not necessarily mean High Speed (480mbits/s).
Yes - it doesn't support high speed, only full speed (12Mbits)
« Last Edit: February 26, 2011, 06:38:14 pm by mikeselectricstuff »
Offline Zad
« Reply #5 on: February 27, 2011, 03:58:05 pm »
Okay then, Atmel ATSAM3U4C 100 pin LQFP. USB 2.0 Device: 480 Mbps, 4-kbyte FIFO, up to 7 bidirectional Endpoints,
dedicated DMA
http://uk.farnell.com/atmel/atsam3u4ca-au/ic-mcu-32bit-256k-flash-100lqfp/dp/1841664
58 in stock, £6:71 each
« Reply #6 on: February 27, 2011, 04:00:56 pm »
dedicated DMA
That's only device, not host
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #7 on: February 27, 2011, 05:27:01 pm »
How about an Oxford Semiconductor (taken over by PLX it seems) OXU121HP? Farnell is showing stock at £4.11 each.
« Reply #8 on: February 27, 2011, 07:24:33 pm »
Nope - only high speed in device mode
Offline deephaven
    • Deephaven Ltd
« Reply #9 on: February 27, 2011, 08:38:08 pm »
Rats, missed that, sorry!
« Reply #10 on: February 27, 2011, 10:56:14 pm »
Here's one from TI
http://focus.ti.com/docs/prod/folders/print/tusb6020.html
Looks like it only has one port though, and a wierd host interface.
Offline desowin
« Reply #11 on: February 28, 2011, 04:48:52 pm »
sure it will, I overlooked this IC.
Thanks!
