The following "Mini ES9038Q2M DAC" $60 Chinese DAC is widely available on eBay and Ali.
Note that the 12v input power has been updated by manuf. to 8.4vdc. The unit comes with a cheap 8.4v adapter.
The adapter power (8.4v) seems to only power the analog section (output opamp).
The USB 5.0v powers, I think, the digital section (dac chip, XMOS chip, logic chips) . The toggle switch powers on/off the 8.4 v. But the LED next to "POWER" label lights up when the USB is plugged in (regardless of 8.4 on or plugged in) -- a confusing scheme!
Here is a top view of the inside:
I was operating the unit with the cover removed and noted a soft buzzing noise. The noise was active ONLY when the USB cable was plugged in. Removing the 8.4v supply made no difference.
Finger testing heat, I noted the components in the USB plug area (top right corner of PCB) getting quite warm AFTER about two min. of operation.
I dug out my IR thermometer and measured 130F (54C) at the USB input coil choke and/or the resistor and/or the inductor next to it. The XMOS chip was about 100F. Everything else was a few degrees above room temp.
Sorry, I don't have a FLIR (yet!).
While I have not performed any objective tests, subjectively the unit functions and sounds just fine.
I think I have noted hot-running USB input sections before in other devices, but can't confirm.
Is this USB input power section behaving normally?
Any tests that can conform/deny defect or long-term reliability of associated components?
Are there mods that may "quiet" or cool things down?
Thx!
NOTE:
I was summing the currents eaten up by the USB power input:
XMOS (45ma)
https://www.xmos.ai/download/XU208-256-QF48-Datasheet(1.16).pdfLEF (20mA)
.....what else?
