A lot of the electronics I work with these days are USB powered. Either via an earth referenced computer PSU or a floating w/ leaking current USB power adapter/charger.
As per other threads I am developing stuff with USB audio, ADCs, DACs etc. This involves connecting a whole bunch of different equipment together.
So far I've been a little hesitant when connecting a breadboard to two different PCs USB ports, this obviously isn't that bad as both PCs have the same (incredibly noisy) ground reference.
However, if I then connect my oscilliscope to that bread board, it's inductors all POP and whine as soon as the ground is connected and it immedaitely starts showing noise of about 1 volt peak to peak with a whole range of frequenies. Even scoping a pulled low MCU pin, has the same noise. The scope is completely floating, DC powered from a battery and why I wasn't really worried hooking it up to the breadboard.
I would like to use a signal generator however to test filters and spot check audio quality etc with the scope. The signal gen has however got a SMPS (that I never did replace). It has the usually 100V+ ground leakage current of uAs. It's still 100V+ though.
I would imagine connecting the sig-gen and PC USB to the same breadboard will be fine. The breadboard can take it and as both USB/PC and SigGen are on the same earth/neutral reference and both have SMPS there won't be much potential across the board? The uA of current will not bother either end as they are used to it anyway.
The scenario I would be more worried about would be connecting the scope to the sig-gen, and then the USB powered breadboard, without first connecting the two grounds together. Would this not lead me into the scenarios that my scope grounds become the conduit for the 100V+ ground current? If the scope is a 50-100V chinese scope... will that result in smoke?
