Yes, "'USB memory' and Arduino on same serial port?" might be the wrong question to ask, but thats why am asking, since I am not sure what to actually ask...
So, what is it I actually want to do? Well the basic idea is to build a datalogger (i.e. a Arduino with an amplifier circuit to read temperature/strain etc.), which when connected to a PC launches an executable from its memory to display the readings (with some additional features). My limited understanding of the issue is that the memory and the datalogger would not be able to share the same serial port and an usb hub circuit would be needed, or is there some nice searchterm to Google? Doing something like alternating between the sources, loading the executable into RAM and then switching to the Arduino serial or something similiar?
Or should I just read up a bit on serial comms?
Thank you in advance, for any searchterms, or other advice you may provide
