Morning all!
Me and a friend are working on an SDR project around the RTL-SDR Dongles, and we have come up with a possible method of filtering noise from the 5V line, but we are in dispute around what capacitor/s to use to do the job.
Here is the board we came up with to do the job, its main intention was to distribute power to 2 devices at the same time from one USB port, but as we were coming up with the design, we decided to add filtering.
The intention was to use a 10uF Electrolytic Cap.
Any insight into what caps to use, or if the design needs tweaking would be greatly appreciated.
Copies of the design files are available if you want a copy.
Thanks!
