To replace Q1 with an npn transistor connect the 723 pin 11 and 12 together with the NPN Q1 collector, the base to pin 10 and the emitter to the pass transistor base.
This configuration will have a higher dropout voltage.
The 723 can drive 150mA without Q1.
If this is adequate, do as David says.
