Author Topic: Use of transformer with 3 coils each having 3 turns  (Read 714 times)
Offline petertTopic starter
« on: December 14, 2019, 08:45:57 pm »
Hello,
I disassembled a CCFL light bulb/energy saving lamp. It has what looks like a toroidal transformer, with 3 coils each having 3 turns only.
I assumed the point would be voltage conversion, but since each of the coils have the same number of turns (even if some are slighty more dense than others), I would assume they don't have much of an effect.
What use would such a component have?
« Last Edit: December 14, 2019, 08:51:36 pm by petert »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Use of transformer with 3 coils each having 3 turns
« Reply #1 on: December 14, 2019, 09:24:01 pm »
Trace two of the windings back to the base-emitter circuit of the two transistors.  I think you will find it's a rather critical part of operation. :)
Seven Transistor Labs, LLC
Offline Zero999
  • 0999
« Reply #2 on: December 14, 2019, 09:48:44 pm »
The transformer actually drives the transistors.
There are some specialised CFL driver ICs, but most lamps use the same basic circuit. See the links below.
http://educypedia.karadimov.info/library/AN00048.pdf#page=11&zoom=auto,-90,632
http://diycarmaint.blogspot.com/2017/11/ccfl-or-cfl-lamp-repair-energy-saver.html
Offline james_s
« Reply #3 on: December 14, 2019, 10:03:40 pm »
The circuit is called a Royer oscillator. They have some disadvantages but it's hard to beat the simplicity. I actually hacked one together out of parts I literally found on the floor once and it worked on the first try, transferring enough power to light a 12V incandescent bulb.
The following users thanked this post: petert
