Hello,
As a beginner, I have tended to use lots of relays for logic and switching, since the way they operate is very intuitive.
I'm staring to understand that in many cases, using transistors for switching is a better choice (cheaper, smaller, better for high frequency switching, etc)
I've enjoyed learning how to use transistors to switch a signal on or off, invert, buffer and provide gain. Very useful.
I'd now like to understand if it is possible to use transistor circuit to switch between two different signals.
Specifically, I'd like to find a circuit which will perform the same function as my relay switching circuit below.
In this case, the MCU digital output state determines which signal from the inputs is connected to the output.
Update: Thanks hamster_nz for spotting the flaws in my relay circuit. It was just a quick sketch to illustrate my question, but you are quite correct and I have uploaded a corrected version which might be useful for people reading the thread in future:
