The part is a Siliconix J2086, I think that's a JFET. I've attached a couple of screenshots, one showing the FET in question (Q8 circled in red). The other showing what it's connected too (the negative input to a null detector/amplifier. Which happens to be the Drain of a J2317)
The drain is connected to a 13v fixed reference voltage
The Gate voltage comes from the output of an LM339 and I measured it at -25v. (The LM339 has a +5v and -25V supply)
I measured the Source voltage at 0v
I perhaps ought to have posted this in the repairs section, as I am trying to fault find and repair an old Fluke instrument. It's a bit of a beginners question though, and I want to try and understand how the FET functions. Partly so I can check the operation is correct in this particular example, and partly because I need to learn these things for future reference.
I have had a google, but feel free to point me in the direction of any useful information. It's probably better I learn about this, and understand why/what/how it works. Rather than somebody just giving me the answer to this particular example.
