Author Topic: Desolder SMD BA5984FP - Ic is glued on the board  (Read 4077 times)
Offline herr-stromberg2010Topic starter
« on: November 05, 2011, 09:11:00 am »
I have problems to remove the BA5984FP vom a pcb. I can use a tweezer or the hot air gun, but the ic is fixed by a very hard to remove glue, mostly I removed the IC the glue destroys the pins on the boad. If this f... glue would not be there It will be easy to do.
Can you tell a newby what to do? or what to use to solve this probs.????
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: Desolder SMD BA5984FP - Ic is glued on the board
« Reply #1 on: November 05, 2011, 10:03:31 am »
Most glues can be softened with hot air.
The way I'd do it is to unsolder the pins with braid, use a knife to ensure all pins are  completely free, then heat gently for a while (lower then desolder temperature) while lifting the IC body with a knife.
Day Job: Mostly LEDs
