Author Topic: Unexplaned voltage drop on the 12V wire from head unit ACC to reverse camera  (Read 296 times)
Offline Charlie WhiskeyTopic starter
Some electrical gremlin must be having fun with the new head unit I'm trying to install  |O
The problem is my new reverse camera not powering up and I traced the problem to the 12V wire that is supposed to supply the power.
Both the camera and the RCA signal cable are fine - I know because I tested them with a separate power adaptor (i.e. from the wall socket) and the head unit displays the image from the camera just fine.
I tested the 12V power cable however and it was only giving me 9 to 10 volts and strangely fluctuates a fair bit.
That 12V power cable is connected to the head unit's ACC cable with a T-tap connector. I had another equally long cable T-tapped to the same ACC wire and that is giving me a steady 12V.
Any obvious ideas I should check for before I pull the head unit and all of the trim panels apart again? I'll probably break a few more pieces of plastic doing that...  :(
My chief suspect right now seems to be that T-tap perhaps not done right.
« Last Edit: June 05, 2024, 05:32:54 pm by Charlie Whiskey »
Online IanB
If you have two sides of a T-tap and one side is giving 12 V while the other side is not, then the signs would point to a fault inside the T-tap, or a fault in the wire leading from the T-tap. It is not likely the fault is upstream of the T-tap.
Found the culprit!
Turns out this connector wasn't quite done properly, and I know the wire was too thin for it. The insulation was holding it in place, but the conductor itself was basically floating in air.
A drop of molten solder solved it. Gremlin terminated.  :box:
Offline CaptDon
  • Country: is
I have run into that scenario several times on a boat that I operate. The boat had a fire many years back and the company who was working on the boat and caused the fire agreed to fix the damage at their cost / insurance. Apparently one of their numb nuts electricians thought that those spade lug connectors were designed to bite through insulation like a T-tap. I have had an endless group of failures. No power to bilge pumps, announciator lights not coming on to warn of certain conditions, intermittent power to other ship systems. What a nightmare!!
