There is no "+" terminal on the mains, but judging by the naming of one terminal as "N" it seems you are in the USA, yes?
The RC values are more appropriate for a 230VAC/50Hz dimmer circuit - try reducing the fixed resistor to 3.3k and the capacitor to 100nF (note that it should be a high voltage film type for safety reasons). Other possible problems are: bad or miswired pot (center and right terminals, with knob facing you); 10k resistor not really 10k (too high or open circuit); diac breakover voltage too high (needs to be around 30V); bad triac; shorted capacitor; insufficient or missing or highly inductive load present - this dimmer circuit will not work without a predominantly resistive load (like a... wait for it... incandescent lamp!).
Triac connections are wrong.. The triac gate has a reference, in this case pin 1. Using the other way round it likely will either be on always or off, depending on the capacitor charging.
Incorrect. Triacs can be triggered by any combination of gate polarity with respect to MT1 (T1) or MT2 (T2) polarity. See relevant excerpt from the BT136 datasheet you posted:
