I'm in the middle of building a PSU, and I ended up ordering a pair of 3 terminal capacitors (instead of the 2 I'm familiar with). I wired up and tested them just using one of the +ve terminals and the readings were as per the book I'm following.
What's the extra +ve terminal for? Also, I'm supposed to have used "phenolic strips" to mount the capacitors, providing a "3 chassis mount insulated tie points" for them... but I don't quite understand. Does anyone know what kind of hardware these would be? A link to some actual parts in say Mouser/Digikey would be very helpful.
Thanks!
