Author Topic: Using a CM Choke from EMI Filter as Transformer  (Read 1310 times)
Offline FrankentronicsTopic starter
« on: April 12, 2020, 11:47:03 am »
Greetings,
A friend of mind wants me to make him an interface to tap a phone line. The device is described here:
https://www.ranecommercial.com/legacy/note150.html
The schematic is here:
He is a musician and he wants to use the phone line to send and receive audio.
So, the device requires a 1:1 transformer and I like to use salvaged parts. Perhaps this is a crazy idea, but can I use a CM choke, salvaged from an EMI filter, to function as a transformer? Of course, it would have to be rotated 90 degrees, or wired "sideways", to be a transformer.
But basically, might that work for this particular application?
Thanks...
"If you obey all the rules you miss all the fun."
- Katharine Hepburn
Offline srb1954
  • Retired Electronics Design Engineer
Re: Using a CM Choke from EMI Filter as Transformer
« Reply #1 on: April 12, 2020, 11:58:18 pm »
It won't work very well at all. A common mode choke won't have nearly enough inductance to work at audio frequencies unless you are prepared to suffer enormous signal loss through the circuit.
A transformer designed for audio frequencies will have a winding inductance of at least several Henries whereas a common mode choke will typically be less than 1mH.
The following users thanked this post: Frankentronics
Offline james_s
« Reply #3 on: April 13, 2020, 04:28:21 am »
Small 600 ohm audio transformers are ridiculously cheap.
https://www.ebay.com/itm/10Pcs-Audio-Transformer-600-600-Ohm-Europe-1-1-EI14-Isolation-Transformer-DIY/173610350428
Well, that's clearly the solution.
Thank you for taking the time to post the link.
- Katharine Hepburn
