Hi there,
I'm working on a circuit based on Adam Welch's 18650 capacity tester : ; where a logic-level mosfet switches the positive terminal of an 18650 through a power resistor to ground. I am trying to switch the mosfet out for a darlington npn transistor (TIP102), but can't get it to fully switch. I have a feeling the battery polarity is somehow creating a high side switch type situation, but just can't figure it out.
I've tried it with lower value base resistors too. I'm using an ATtiny85, it puts out 5.5v and can source 40 mA.
I've a attached a rough schematic, I'd really appreciate any help. I was thinking to put a pnp there but I'd like to understand what's going on also...
Thanks a million,
Brian
