Author Topic: using a tek 2430 scope  (Read 2121 times)
Offline m3vuvTopic starter
« on: January 06, 2022, 05:12:58 am »
Hi all,i was miss sold a tek 2430 ,instead of beeing a 2430A as advertised,turns out it isnt the A model but a 2430 non A,ive beeing looking at signals from a sig gen on this,i want to be able to display the frequency in mhz etc,i can see the % duty cycle etc but cant seem to get it to display the frequency,is it posible with this non A version?,i know the A version has more math functions,is displaying frequency one of them?,this was the original listing:https://www.ebay.co.uk/itm/Tektronix-2430A-Oscilloscope-/294643654575?nma=true&si=pafAtsKxNpZVz9IsNtJq%252FWUFbig%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
The poor display was just dirt behind the blue screen filter,the other  issue was a FPP self test fail,that was fixed by replacing the LTC-7P nv ram battery,being able to display frequency was one of the main reasons for buying this,if it cant be done i may send it back for a refund as it was not as listed,TIA.
Offline Squarewave
Re: using a tek 2430 scope
« Reply #1 on: January 06, 2022, 05:24:45 am »
Usually on the Teks you use the Measurement function, then select what you want to measure.
« Reply #2 on: January 06, 2022, 05:57:32 am »
Do you know the 2430?,i see no measure button on this one!!,maybe the A has that and this one doesent?
Offline Jeff eelcr
« Reply #3 on: January 06, 2022, 11:55:22 am »
On the 2430 it looks like the frequency is measured by the cursors (no measure button) see pages 3-8,9 4-15 (1/time) 6-15,16 in the operators manual.
Jeff
Offline Ground_Loop
« Reply #4 on: January 06, 2022, 05:57:54 pm »
You have to do it with the cursors. Press the function button in the cursor area then select 1/time in the on screen bottom menu.  Adjust the vertical cursors to one wavelength.  BTW I'm going by how my A version operates.
There's no point getting old if you don't have stories.
« Reply #5 on: January 08, 2022, 10:33:24 am »
ive tried that but still see no way to get a frequency readout,can the non 'A' 2430 actualy do this,i know the A version can as it has different firmware,can this be done on the non A version tho,thats the heart of the question.
Online David Hess
  • DavidH
« Reply #6 on: January 10, 2022, 05:47:48 am »
The 2430 (without the A) lacks automatic measurements.  You can use the graticule, cursors, and delayed timebase to make measurements just like on an analog oscilloscope.
« Reply #7 on: January 11, 2022, 02:33:32 pm »
Cheers david,thats what i suspected,i wonder if the A stands for automatic,as in measurements?
Offline CaptDon
  • Country: is
« Reply #8 on: January 11, 2022, 02:43:01 pm »
'A' as in revision A, like 'B' as in TDS2004,TDS2004A (not released in quantity) and TDS2004B the final hardware revision for that model. Similar to the TDS420 and TDS420A which had hardware and software revisions.
Online David Hess
  • DavidH
« Reply #9 on: January 11, 2022, 08:34:37 pm »
Later DSOs in the series had automatic measurements but not A suffix, like the 2440.
« Reply #10 on: January 12, 2022, 12:16:14 am »
just a word of warning for folks,avoid ebay seller taylor _D2010!,he is a total scammer!
« Reply #11 on: January 12, 2022, 02:29:04 am »
i didnt accept the refund as that would of left me swallowing the £25 postage,he did eventualy refund me that then was looking like he was trying to stop it,just been a lot of agro buying something misrepresented!
Offline w2aew
    • My YouTube Channel
« Reply #12 on: January 12, 2022, 03:04:21 pm »
Frequency is measured on this scope manually using the 1/TIME cursor function.  See page 4-15 (page 85) of this manual for the details:
https://w140.com/tekwiki/images/b/b4/070-4918-00.pdf
FAE for Tektronix
Offline PlainName
  • Country: va
« Reply #13 on: January 13, 2022, 12:37:45 pm »
In case anyone gets here via a search and doesn't know the context, a fuller explanation of who scammed who is here:
https://www.eevblog.com/forum/buysellwanted/ebay-scammers/
The following users thanked this post: gnif, rogerggbr
« Reply #14 on: January 13, 2022, 03:29:49 pm »
just wish i never brought the thing with the agro its caused!,mods please delete this thread.
Online FireBird
  • Country: at
« Reply #15 on: January 13, 2022, 04:01:17 pm »
Guess who has triggered it.
Online tggzzz
« Reply #16 on: January 13, 2022, 04:27:20 pm »
I suspect (and hope) the mods will not delete the thread.
A common joke used to be (and by some accounts will be again) "Students of Soviet Russian history know how difficult it is to foretell the past".
Offline gnif
« Reply #17 on: January 14, 2022, 02:18:20 am »
Correct, it's our policy to not delete threads/posts unless they are in breach of forum rules.
There is nothing here to warrant removal of this thread.
