Hi all,
Thanks to you and @Kleinstein, this has become very interesting and a little confusing.
My goal here was to use an ATmega328p, an ADC and a screen or LCD in order to 'free up' my multimeter, I want to output the microcurrent to a seperate screen that way I can use the meter at the same time, but I see that it's not quite as simple as I first thought, I have been reading up and thinking about what you have said, and I clearly need something between the microcurrent and the ADC, something that the fluke has.
Is this some type of buffer like an OPAMP ? or could it be a high pass filter consisting of a cap and a resistor (probably not that easy!) what I now no is there is about 3mV of 50Hz ripple on the output of the microcurrent, this seems a lot to me, but the fluke appears to compensate or reject this in some way, I was reading the data sheet for the ADC and tried adjusting the sample rate to observe the effect but had no sensible results and I am using the PGA with a gain of sixteen, this is configured in the arduino library, I haven't added much but have you any thoughts on the path I should take ? another multimeter would be easier but not an option at the moment and this way I might learn something. If it were another stage needed I have some Burr Brown INA105KP instrument amplifiers, these are good quality devices that are used in the measurement field, I wonder if they could be useful (random thought) Not sure what to do next any suggestions would be great. The Arduino is running from a 9v battery and the microcurrent has its own 3v supply, the output is fine on the fluke. Just thought, perhaps some transistor output stage maybe what I need ? but now I'm just guessing, but worth a look...cheers.
Andy
