Author Topic: using MC33151 with Arduino  (Read 1239 times)
Offline hussamaldeanTopic starter
  • Country: iq
« on: July 21, 2018, 07:13:13 pm »
Hi all,
I want to use this mosfet driver with arduino or other 5V logic IC to driver IRF150 or IRF510. However, once I apply the signal, nothing happen like there is no input signal at all and I can see clearly with oscilloscope the pwm signal is working fine while the output is maintained at the applied voltage.
is there something wrong or the IC is burnt ?
note: I connected the output directly without any resistor or capacitors
« Last Edit: July 21, 2018, 07:22:02 pm by hussamaldean »
Offline JS
  • Country: ar
Re: using MC33151 with Arduino
« Reply #1 on: July 21, 2018, 07:27:35 pm »
Mosfet drivers usually need two separate rails to provide the floating power for the output of the driver.
JS
If I don't know how it works, I prefer not to turn it on.
  • Country: iq
« Reply #2 on: July 21, 2018, 07:41:43 pm »
JS
could you please elaborate ?
Offline JS
  • Country: ar
« Reply #3 on: July 21, 2018, 10:45:46 pm »
JS
Not much right now, but floating mosfet use driver with a secondary power source, for now go to de datasheet to check, when I can I could elaborate a bit more
JS
  • Country: iq
« Reply #4 on: July 22, 2018, 09:50:10 am »
JS
JS
I am using 12V for the mosfet to drive the load while the mosfet driver is powered via 5V and share same ground
Offline HB9EVI
« Reply #5 on: July 22, 2018, 10:26:53 am »
the driver doesn't work with a supply voltage of 5V, since it has an undervoltage lockout of 5,8V. Also it doesn't make much sense to supply it with 5V - then you could drive the fet directly with logic output of the mcu.
you can simply take a logic level fet and spare you the driver
  • Country: iq
« Reply #6 on: July 22, 2018, 07:51:13 pm »
I scraped the idea of using mosfet and mosfet driver and used L293D instead and it does work wonderfully
