Hello guys i am a beginner in pic micro controller programming. i have a code for frequency measurement using pic 18f4550 microcontroller.but the problem is although the code sometimes works in real hardware but it did not simulate i Proteus simulation software. This code is very important for me since I want to understand how capture module works in pic.Can any guys fix this code as well as post the simulation file in this forum so that i can download them and simulate it.Or provide some alternative code for Testing capture module functionality of pic 18f4550.
// some random garbage uncommented code found on forum
// 20MHz external crystal with no PLL to give 20MHz system clock
// a 5 kHz test square wave is provided on RC1 - link RC1 to RC2 to test operation
#define f_timer 5000000 // T1 clock is Fosc/4
sbit LCD_RS at LATB4_bit;
sbit LCD_EN at LATB5_bit;
sbit LCD_D4 at LATB0_bit;
sbit LCD_D5 at LATB1_bit;
sbit LCD_D6 at LATB2_bit;
sbit LCD_D7 at LATB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
void main ( void ){
unsigned long signal_period,data1,data2;
char frequency_Hz[20];
float Frequency;
Lcd_Init();
TRISC.TRISC1 = 1;
OSCCON = 0b1110000;
PIE1.CCP1IE = 1;
PIR1.CCP1IF = 0;
CCP1CON = 0x05;
CCPR1 = 0x00;
PIR1.TMR1IF = 0;
T1CON = 0x80;
T1CON.TMR1ON = 1;
TRISB = 0;
TRISA = 0; // all outputs
LATA = 0; // all low to start with
TMR1H = 0;
TMR1L = 0;
PWM2_Init(5000); // provide test frequency output on RC1
PWM2_Set_Duty(127); // square wave
PWM2_Start();
while( 1 ){
while(!(PIR1.CCP1IF));
PIR1.CCP1IF=0;
data1 = CCPR1;
PIR1.CCP1IF = 0;
data2 = CCPR1;
if(data1 < data2){
Lcd_Cmd(_LCD_CLEAR); // clear out old information
signal_period = data2 - data1;
Frequency = ((float)f_timer / (float)signal_period);
FloatToStr( Frequency,frequency_Hz );
///LongWordToStrWithZeros(Frequency, frequency_Hz);
Lcd_Out(1, 1, frequency_Hz); // display new frequency value
TMR1H = 0;
TMR1L = 0;
Delay_ms(500); // Limit display rate to reduce flicker
