Author Topic: Using polarized capacitors in place of bi/uni/non-polar electrolytic capcitors  (Read 2378 times)
Offline drewt86Topic starter
Hi gang,
My name is Drew and while I've been watching EEV on youtube for years, this is my first time on the forum. I'm still learning and recently took on a project to repair a device of mine that stopped working.
After a power supply issue I had with a Presonus Central Station, I decided to order all new caps. There were only 30 on the board and figured it couldn't hurt while I had it apart. Since I'll be receiving the parts on Friday, I came in today to remove the capacitors from the board and document the layout/orientation, etc. As I was desoldering them, I discovered that although they are electrolytics, some of them or nonpolarized. I didn't notice it until I went to look for the minus. My bad, if I had discovered this earlier, I would have replaced it with poly caps.
Here is a spec sheet one type of capacitor on the board in question. http://www.vek-online.de/files/4188/upload/Elektrolyt/CD71H.pdf
The ones on the board are made by the Chang Yang company...and to be clear, I didn't make that name up. That's what they say on them...
Anyway, my question is, is it possible to use a polarized capacitor in place of it? I know you can't go the other way around but this is the first time I've thought of this. Is there something special about how I should orient it? Most of these bipolar caps appear to be filtering outputs of the MC33079 all over the board. Each cap is in series with a 50ohm resistor from the output and ends up at some relays on a different board. Sadly, there is no schematic to be released.
While I've been learning a lot in the past few months, I still have many gaps in my electronics knowledge and I just found one. Any help is appreciated.
Offline danadak
Without seeing the schematic , in general. a polar cannot replace a
non polar. Exception is use of two polars used in series, like polarity
connections, eg. + to + or - to -, to create a non polar.
Regards, Dana.
The following users thanked this post: drewt86
Offline Zero999
  • 0999
Yes, use the same value capacitors, connected back-to-back. The capacitance will be half of the original capacitor value.
https://www.quora.com/What-is-the-difference-between-AC-and-DC-capacitors
http://www.electronicecircuits.com/electronic-circuits/crossover-network
