Author Topic: using solder paste out of a tub  (Read 7597 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« on: April 10, 2014, 08:17:06 am »
so I bought a cheap pot of solder paste ff ebay. I opened in and this guey lump was in there, not really liquid at all but creamy. I couldn't suck it into my siringe even with the biggest tip and pushing it back out again was also hard and not easy to dose. Result was that I got my parts soldered and not bad for my first attempt but gee that was hard work and not anything I'd feel happy presenting to anyone.
How do you use solder paste out of a tub ?
Should I just pay the money for a pre syringed one ? how liquid versus solid should the paste be ?
Offline Fsck
  • sleep deprived
Re: using solder paste out of a tub
« Reply #1 on: April 10, 2014, 08:24:36 am »
pull out the plunger, pack it in, use a large enough nozzle st it doesn't require large amounts of pressure, replace plunger.
can be a variety of viscosities, but the two extremes (liquid or solid) are bad. usually something tacky, sort of like freshly mixed 2-part epoxy is nice and holds stuff down quite well.
probably personal preference, but I don't like pastes that aren't really pastey.
« Last Edit: April 10, 2014, 08:26:15 am by Fsck »
"This is a one line proof...if we start sufficiently far to the left."
Offline Monkeh
« Reply #2 on: April 10, 2014, 08:30:39 am »
With a spatula and a stencil.
Offline Kjelt
« Reply #3 on: April 10, 2014, 08:41:36 am »
The paste from a tub is for stencil use, not for syringe use. The lead balls are much bigger and stiffer then paste from a syringe (look under the microscope).
That is why the paste from a syringe is probably also more expensive per gram than from a tub.
You can put it in a syringe (indeed pull the plunger out stick with a spatula some of the paste inside and press the plunger till all the air is out then apply the nozzle) but only if the nozzle is big enough, you can forget about the extreme small nozzles.
The paste is going to be a bit more slimy (more usable) if it is at room temperature. Also I heard/read some people adding extra flux but I do not know which exact flux would work.
Oh before I forget you should always mix the paste thoroughly in the tub for consistency that also helps make it more slimy.
Offline Simon
  • Global Moderator
« Reply #4 on: April 10, 2014, 08:50:52 am »
ok I'll have to get a prefilled syringe, I used the biggest nozzle my syringe set had and it was still impossible and it's actually too bit a "needle".
Offline amyk
« Reply #5 on: April 10, 2014, 09:12:39 am »
It's called "solder paste" and not "solder fluid" for a reason. ;)
Offline Kjelt
« Reply #6 on: April 10, 2014, 09:14:11 am »
You are sure the needles are for electronics application ?
My gf works in a hospital and brought me a lof of different needles with luer lock which I thought at that time were just perfect but none (even the extreme big ones) worked with solder paste because they have some kind of filter inside blocking it  :(
Offline Simon
  • Global Moderator
« Reply #7 on: April 10, 2014, 09:38:25 am »
No filters in mine, it's just that it's rolling paste not syringe past I guess
Offline peter.mitchell
« Reply #8 on: April 10, 2014, 09:47:01 am »
Paste in a tub is fine for hand application with a syringe, as others have said, just get something to scoop it out and pack it into the syringe. Regardless the quality of solder paste you should have no troubles dispensing it out a syringe, the balls are far finer than the needle (provided you didnt get a tiny 32ga or something, you have pref 20~16ga needle), it will just require a bit of force pushing on the plunger...
Offline Simon
  • Global Moderator
« Reply #9 on: April 10, 2014, 09:54:40 am »
well i did get some into the syringe and it was dire trying to dispense it, way too thick
Offline Kjelt
« Reply #10 on: April 10, 2014, 10:36:12 am »
Just from your description and if the paste is at room temperature i suspect it could be spoiled.
Even the tub paste should be able to smoothly glide over a stencil without too much friction, might be mistaken your words but it sounds like it is pretty dry (dried out).
Offline Simon
  • Global Moderator
« Reply #11 on: April 10, 2014, 10:46:00 am »
I think it was in ok condition and I had kept it in the fridge but I think it being cheap stuff off ebay was just not made for syringe use.
Offline CTMS
« Reply #12 on: April 10, 2014, 11:00:02 am »
The main difference between solder paste in a syringe and a jar is that amount of flux added when manufactured.
Generally on a tub if solder paste you will see a metal content i.e. 90%, this means 90% metals / 10% flux. Solder paste in jars is generally used in manufacturing with stencil printers and companies do not want to have solder paste too runny and want minimal residue.
When solder paste is manufactured for syringe dispensing it is generally made with a higher flux content for easier dispensing. You can always buy solder paste in jar and dispense into smaller syringes but generally it will dry out faster and can be messy.
Regarding dispensing needles to use for syringes, you would be best to use a taper plastic tip as appose to a metal tip. You would not go any smaller than a 20 gauge tip. If you go smaller then the solder balls in the paste will not make it through the tip and you will struggle to dispense the paste.
Element 14 have the paste available in syringes and small jars, both use the same ball size, only difference is the syringe mix has more flux mixed in it.
http://au.element14.com/aim-products/ct-l63-s0515/solder-paste-63-37-183-c-15g/dp/2366335
http://au.element14.com/aim-products/63nc257-2-j250/solder-paste-sn63-250g/dp/1827457
Offline sleemanj
  • Professional tightwad.
« Reply #13 on: April 10, 2014, 12:02:27 pm »
You did allow it to warm up first before trying to dispense it though didn't you.  Store in the fridge, but you must allow it to return fully to room temperature before using.
You could always add in a little extra paste flux - it's not like you're in a high production setting where you need to adhere to exact specifications (otherwise you wouldn't have bought from ebay in the first place), so just experiment a bit.
« Last Edit: April 10, 2014, 12:04:52 pm by sleemanj »
Offline Simon
  • Global Moderator
« Reply #14 on: April 10, 2014, 12:06:19 pm »
yes maybe although it was not like it was a tube that was 1/2 "full" it was in there as a blob so was in a blob before it even went in the fridge, not sure if that is right but yes i guess i should let it warm next time.
Offline Teledog
« Reply #15 on: April 10, 2014, 04:10:15 pm »
I've had a couple of "tubs" of solder paste in the fridge for years.
Like other posters have said, let it warm up first.
I suck it up into a 1 ml syringe without the needle.
The smaller the syringe, the easier it is to work with, ..but you may have to fill it more often.
Then you might want to experiment exuding it with different needle gauges, depending on the ball size of your paste (#16-#18-#20?)
Also (Very important!), make sure your needle is short ..a long needle is much more difficult to press goop through than a short one.
If you cut it down, just make sure you don't pinch or have a burr blocking the needle tip/hole.
G'luck!
Offline Kjelt
« Reply #16 on: April 10, 2014, 05:23:50 pm »
Does it have an extra plastick cover that goes inside to fully cover the paste from drying out? That is how the good brands have their paste packaged.
If not I would suggest next time (if there is going to be a next time) cover it with a plastick sandwichbag or something like that so the flux does not evaporate and the paste does not dry out.
If you look under an microscope can you still see the solderballs "swimming" in flux like in frog spawn or are the solderballs dry?
Did you stir for a minute in the paste so it is good mixed?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #17 on: April 10, 2014, 05:31:59 pm »
You can thin paste with flux if necessary, but as mentioned tubs are usually printing grade, not dispensing, and have a much thicker consistency
Day Job: Mostly LEDs
Offline Simon
  • Global Moderator
« Reply #18 on: April 10, 2014, 05:52:52 pm »
swimming ? stir ? that's my point, it's too thick to.
Offline Kjelt
« Reply #19 on: April 10, 2014, 06:03:06 pm »
I thought let's make a picture of the two types of paste for Simon since I have both of them at the moment and show you the difference.
To my surprise the size of the solderballs for this batch are both almost equal of size (that does not mean yours might not be much bigger as my previous brand was).
The big difference is the amount of flux as you (hopefully because my usb microscope is bad quality) can see in the pictures, the paste from the syringe is literally swimming in flux and it is absorbed by the paper while the jar stuff is relatively pretty dry. The reason is that if you use a stencil you want the paste to stay vertically in place and not just collapse and make contact with the other isles of paste.
So the solution for you is take a bit of paste from the tub, add thin as possible noclean flux (don't know what kind/brand) and stir till it is slimy.
Offline Simon
  • Global Moderator
« Reply #20 on: April 10, 2014, 06:46:22 pm »
yes it does seem to be a flux versus solder problem.
Offline ion
« Reply #21 on: April 10, 2014, 08:02:35 pm »
I think it was in ok condition ...
I was a bit less optimistic with the cheap stuff on ebay.  The solder ball test seemed to be a quick way to tell if the paste is any good:
www.ipc.org/4.0_Knowledge/4.1_Standards/test/2.4.43.pdf
Offline fluxcapacitor
« Reply #22 on: April 11, 2014, 12:54:17 am »
I use mechanic branded solder paste from ebay.It i quite solid the first time its opened.I dont keep it in the fridge just in a cool place, then i stir it up with a small screwdriver until its thin enough to use. I use an old syringe from an ink refill kit ,it does the job.
Offline macboy
« Reply #23 on: April 11, 2014, 02:18:47 pm »
I would think you can just thin it with IPA, since rosin flux is essentially just solid rosin dissolved in IPA.
If it is too thick to stir the IPA into, just add a little (less than a mL), cap the jar, and let it sit for a day at room temp.
Offline Simon
  • Global Moderator
« Reply #24 on: April 11, 2014, 03:15:26 pm »
got some flux from the radiator building shop at work and mixed it in.
