Hello,
I often find myself having to probe PCBs with lots of surface mount components of varying shapes and sizes. Think tall electrolytic caps, lots of varying connectors, debug headers, standoffs, etc. Because of all the "clutter" on the board, it is difficult to measure voltages on the board with a scope. I usually sprinkle around a bunch of test point pads, but accessing the test points with the scope can be difficult when probing 4 signals simultaneously. Furthermore, getting a good ground at the same time can be difficult because of the limited space. I already have a set of PCBite probes, and while they are useful they're still a bit finicky with small test pads.
This inconvenience has me thinking: why not use an RF connector, such as the Murata SWG-series MM8030 SMD connector, for my test point needs? These are cheap (around 10 cents/piece in the quantities that I'd buy), and give me both signal and ground which I can connect directy to my scope by using the Murata SWG probe and an SMA to BNC adapter that Murata also sells. This would allow to me to conveniently probe signals around my PCB without having to deal with test pads or ground clips.
Are there any pitfalls with this approach that I'm not thinking of? I would mainly use this for non-RF probing, such as probing PWM lines, shunt voltages, I2C/SPI/UART busses, and some analog signals. My scope has a 50Ω input so as far as I can tell, I just need to adapt the SWG connector to BNC and I can plug it directly into my scope. No ground clips needed! Will the 50Ω impedance have any issues with the types of signals I plan on probing?
Also, the Murata SWG series is a switched connector, so when I plug in my probe, the signal will be disconnected from the rest of the circuit. This isn't ideal for my purpose, as I would like to see these signals "in action". Is there any issue with modifying the footprint to short the switch out so that the signal is always connected whether a probe is connected or not?
Thank you in advance for any advice you may share.
