Author Topic: ut210e beep diode hack?  (Read 655 times)
Offline smileTopic starter
« on: October 31, 2021, 09:32:22 pm »
Hello, how do I make the ut210e beep in diode mode?
Offline BreakingOhmsLaw
  • Certified solder fume addict
Re: ut210e beep diode hack?
« Reply #1 on: November 01, 2021, 07:19:25 pm »
The UT-210 does not do that. It will just show the diode junction voltage. Typically between 0,5 and 0,8 Volt for silicon diodes. LEDs have more, depending on its colour. Old-school germanium diodes have less, about 0,3V.
« Reply #2 on: November 04, 2021, 10:22:04 am »
I thought this model was hacked, even scope output was added. Is there no fix to beep on diode mode? checking diodes for short it's not nice to have to look at the LCD every time, sound indicator would be better.
