Author Topic: V+ and V- from 24v dc  (Read 2264 times)
Offline loop123Topic starter
Re: V+ and V- from 24v dc
« Reply #25 on: January 31, 2024, 01:35:35 am »
The  data sheet says an absolute maximum of ±18V, so it should be fine.
https://www.ti.com/lit/ds/symlink/iso122.pdf
But remember a pcb contains all other components. Usually what components can't survive past 18V (+, -)?  Transistor? diodes? capacitors? resistors? ordinary ic? etc?
Online Zero999
  • 0999
« Reply #26 on: January 31, 2024, 02:36:10 pm »
It's impossible to answer that question without reverse engineering it to some degree.
There are parts on the board which might be damaged by 18V, but it depends on how they're connected. For example there are parts which are only rated to 5V, but there appears to be a voltage regulator: VRx, the TO-92 part, on the left hand side of the board, near the red, yellow and brown wires cabled tied together.
« Last Edit: January 31, 2024, 07:59:18 pm by Zero999 »
Offline brucehoult
« Reply #27 on: January 31, 2024, 11:58:06 pm »
It's a type of package. Many different parts come in this package style.
https://en.wikipedia.org/wiki/TO-92
Looks like LM336, a 2.5V "reference diode".
« Last Edit: February 01, 2024, 12:00:36 am by brucehoult »
« Reply #28 on: February 01, 2024, 10:54:13 pm »
Guys. While you still remember a bit the circuit and before you forget them. I want to know if any noises can couple to the main unit and is it better to have a separate power supply for an isolation head that connects beween main units and electrodes? I'm fixing the connectors of the isolation head and need to decide whether to create separate dc pack for this instead of getting it from the main circuit shown earlier. Thank you.
1998793-0
