Author Topic: Values for RC network  (Read 662 times)
Offline PsburgTopic starter
« on: September 17, 2020, 01:46:38 am »
Trying to figure out what capacitor and resistor value (and wattage rating) is needed for this on a 110v 15A outlet? (or just open ended without the inductor)
Do I just use Ohm's law to get the resistor value (=7.3Ω)? and the wattage rating, V x I (1650W?)?
Offline ledtester
Re: Values for RC network
« Reply #1 on: September 17, 2020, 02:50:55 am »
What exactly are you trying to do? C and R can be anything, but supposedly you want certain values to accomplish some task.
And is this a homework problem (which is ok) or a project?
Offline bob91343
« Reply #2 on: September 17, 2020, 04:41:23 am »
It appears to be a simple circuit, amenable to ordinary analysis.  Perhaps if you explain what you want we can show you how.
My keyboard is a pain when it comes to equations so I won't try to type them here.  But you have two series impedances, one is the capacitor and the other is the parallel combination of a resistor and an inductor.  The capacitor will pass current at 60 Hz, which is omega = 377.  The reactance of the inductor is equally simple.
« Reply #3 on: September 17, 2020, 05:59:40 am »
Sorry I should have explained, I just want the 90 degree phase shift this is supposed to produce.
Offline ledtester
« Reply #4 on: September 17, 2020, 07:19:05 am »
Are you familiar with the "Element Impedance" table on this page:
https://www.electronics-tutorials.ws/accircuits/series-circuit.html
1068468-0
Online Vovk_Z
  • Country: ua
« Reply #5 on: September 17, 2020, 03:08:22 pm »
+90 degr. shift or minus 90 degr. shift? And in what exact wire?
To current was shifted by 90 degree there must be only an inductor (without the resistor and the capacitor) or only capacitor (without the resistor and the inductor). Only a voltage source and a one reactive element.
« Reply #6 on: September 17, 2020, 07:12:32 pm »
+ or - 90°, either would work, but not looking for a current offset from voltage like with an inductive load, but both offset 90° from the main line, I think it is called transient response or time delay?
« Last Edit: September 17, 2020, 09:55:40 pm by Psburg »
