Author Topic: variable dc power supply design  (Read 2049 times)
Offline shibas
« on: July 10, 2013, 08:30:20 am »
How can i build a variable dc power supply variable from 0 volt to 150 v?
Offline airiclenz
    • Airic Lenz
Re: variable dc power supply design
« Reply #1 on: July 10, 2013, 08:59:27 am »
Do you just want the schematic?  >:D
...you need to give some additional details regarding your requirements to the final PSU. Where do you live (110V mains or 230V?), what amp-range should it cover? Do you need a clean output or can it be s switching PSU? ...
Airic
« Last Edit: July 10, 2013, 09:13:45 am by airiclenz »
Offline mariush
« Reply #2 on: July 10, 2013, 09:40:05 am »
With patience and carefully not to kill yourself ... kinda of a stupid question.
Here's the design of a 0-120v 1A linear power supply, simplifying it to use regulator potentiometers only and adapting it for 150v wouldn't be such a big problem if you know the basics:
